5.3 and 4l60
mcolor
Can you take a 5.3 that was on a z71 and bolt it one a 4l60
If it has the correct bolt pattern on the bell housing.
The 4l60e will need a tail housing for where the transfer case bolts up unless you plan on using a transfer case.
Probably much easier to find one from a 2 wheel drive.
I believe I will wait for a 2wd because I want to make this as easy as possible thanx for the advice
Sent from my SPH-L710 using TurboBuick Mobile mobile app
