5-6g to spend what will i need for 10's
ssleeper94
will it run?
I got aboug 5-6g's to spend on my T. The car is for the msot part stock. I know i'm goign to need. I'm in the process of putting a t400 w/ a brake and a 3500stall, so what parts would make a great streetable but 10sec capable car.
Its gonna take more than $5K-$6K to have a car that can reliably be run into the 10s on a regular basis. IMO Your looking at building the money pit and your better off buying a car that someone else built. How do I know??? In my build up ive got over $15K in engine/tranny :eek:
Buy built or go Stage engine and youll be better off in the long run. Im sure several people will disagree.Just my $.02
I disagree in part with the last post. I got my TTA to run MPH numbers that would have put it in the 10's with a real good 60' time and have nothing more than a TE45a, 50's, THDP, Walbro 340, powerplate, stock IC, and the basic garage tricks. Here is what I would do if I were you....copy Jason Cramers build up and call it good! You would be surprised how little he has and how fast he goes. You could eliminate some of the things he has to keep the budget in the black, but for the most part you could get real close with what you have to spend.
Here it is:
Here is the build up of my car. All work done by me and my dad Tom Cramer less the Trans.
1987 Buick GN T-top. 3610 lbs. with driver.
Engine
Stock 109 block
Stock Crank .01 rods .02 mains balanced at 50% on bobs.
+.030 TRW pistons with light weight JE wristpins
Stock Rods with ARP bolts.
Stock Main caps
RJC Racing Girdle
Total seal rings
Comp 218/218 flat tappet hyd cam. (off the shelf)
As cast GN1 heads with minor bowl work done by me.
84-85 GM Stacked steel shim head gaskets
ARP head studs torqued to 85 ft/lbs.
Champion Scorpion Chevy style 1.6 rockers
RJC valve cover extensions with stock valve covers
Ported stock intake done by myself
Precision plenum
RJC A.D. power plate for the precision plenum
70MM T.B.
HR Parts poly motor mounts
RJC Race crank pulley
All factory accessories.
Turbo
PT-70 P trim 3 bolt turbo, precision 85 exhaust housing.
Fuel/engine management
FAST engine management tuned by me with pointers from Cal Hartline.
72# MSD injectors
MDS DIS 4 HO.
Stock fuel lines.
Acufab Adj. Regulator
Dual XP pumps setup by Tom Cramer, 2nd pump on at 17# of boost.
Intercooler/exhaust
CAS V1 front mount
Terry Houston 3.5" down pipe and exhaust
Stock style waste gate.
Terry Houston headers.
Transmission
Len Freeman of Performance Transmission in Las Vegas
The real Art Carr 9" converter "N" stall
Stage right Brake. Launch at 4500 rpm @ 20# of boost.
B&M shifter
Suspension Rear:
Stock 3.42 rear end, Moser 28 spline axles
South Side machine lowers, stock upper control arms
Dual air bags both at 20#
Blistien rear shocks
T/A rear end cover/girdle
ATR sway bar.
Front:
All stock, even shocks, sway bar removed
Interior
Stock with little Jace’s GN car seat by Jax seat covers.
Chassis Craft chrome-moly bar, installed by friends & myself
Power seats, locks, windows, antenna, trunk release, concert sound with all 6 speakers.
Cold A/C.
Body
Fiber glass front bumper and front aluminum bumper supports. Rolled rear outer fender lip. everything else stock.
Tires/Wheels
Front Weld 15x5 on Big O 225/75/15
Rear Weld 15x10 4.5" b.s. 28x10.5 MT Slicks
Best Performance
1.37 60’ 9.96 @ 133.5 ¼ mi
Race Jace
Jason Cramer
GSCA #2267
RJC Racing
www.RJCRacing.com
801-647-1597
Broke1 is right, always cheaper to buy built, and it will probably cost you more to get in the 10s on the street. But, where is the fun in buying built? The best part for me is seeing the impovements from mods, and watching the car YOU built kick ass.
Just the heads, turbo & FAST system from Jason's combo would be ~$5k! Unfortunately going 10's reliably takes a good chunk of $$$$$$$$!!! There's also a BIG difference between a 10.80 combo & a 10teen combo....
I've got about $6500 into my car's buildup & I've got a good $1500 more to spend (headwork, more turbo, etc...) before I'd feel comfortable running 10's (10.5 ~ 10.7) on a consistent basis. Then again I'm a big believer in overbuilding then de-tuning a bit, just to keep things together longer. ;)
Here are the meat & potatoes of my car's build:
CPP Competition shortblock (balanced & blueprinted): stock block, new stock crank, CPP spec 206 cam, 9:1 forged pistons (Venolia), billet caps on the centers & Race Jace engine girdle.
Stock heads freshened up with new springs etc... & 3 angle valve job
Ported stock intake & modded doghouse w/ 65mm throttle body
50# injectors (w/ matching CPP street chip burned for my combo)
Walbro 340, hot wire kit & Accufab billet regualtor
John Craig TE-61 turbo w/ PTE .63 exhaust housing
Terry Houston downpipe into a 3" Torque Tech exhaust with Dynomax Race Magnum bullet mufflers
Action Fab "stretch" intercooler
S&B air filter / homemade cold-air kit flowing into a solid MAF pipe
HR PartsNStuff poly driver's side motor mount
Mike Kurtz (Century Transmission) built tranny w/ an old Art Carr 3200 rpm 9/11" converter
Stock 3.42 w/ 28 spline Moser axles & c-clip eliminators
HR PartsNStuff lower & upper rear control arms
Average ET's in "fun mode" (xylene blend, street chip, 22~23 lbs of boost & 28 X 10.5" slicks) have been a solid string of 11.4's @ ~119.5 mph with 60 foots in the low 1.6's. It SHOULD be able to dip into the high tens on a race chip, C16 & ~25 lbs of boost but I'd rather ENJOY my car than rebuild it! ;)
Doug C.
A couple of years ago, I drove to Bristol from Charlotte, ran high 10's for the whole week and drove home. Basic setup was:
Champion Iron Heads
55# Injectors (but I would buy 72's instead now)
THDP
TRW forged pistons and Steel Mains
TE-64 (A TE-45A is same money and a bit bigger)
FM Intercooler (I may have had stock with big neck can't remember)
Single XP Plus pump
Reed 214-208 Flat tappet Cam
Stock ECM with Chip I tweaked for my car.
Talk to Red, he proably doesn't have much more in his build up and he's been like 10.43@133.x But he did do all his own work which keeps costs down ALOT.
turbov6joe how many times have you rebuilt or had to pull your engine??? Your car is also a TTA and ran better than TRs did off the showroom floor. There is a '86 T Type in the cars for sale section for like $12.5K and it pretty much has my same combo,I think he runs mid 10s. IMO buying built is the best way to go.If I had it to do over again ID BUY BUILT!!! ;)
