5 bar map help
EVIL87
I need some info on 5 bar map installation on my xfi.
I called fast and they said the ve table can only be 16 x 16 grid.
Which is probably not going to be too precise. I drive this car everywhere so i need the ve table to be streetable at the bottom and precise on the top, but with a 16 x 16 grid i have a feeling its going to be hard to do get the best of both worlds.
Im trying to run about 40 pounds.
Any help would be appreciated.
I run a 5 bar with no problems but if you want more resolution 4 bars are available.
The MAP sensor does not have to dictate the resolution. I suggest contacting your vendor (don't know if it's me). Make sure you have the correct MAP Calibration. The one from FAST is incorrect.
Finally got some good info from the xfi guru cal hartline.
Thanks cal, cool new website.
