55lb Low Z injectors and TurboTweak chip $100
jdpolzin
I've got a set of 55lb injectors and two cips. One chip is from Turbo Tweak and the other is a Reds chip. $100 ----Jeremy
Injectors were used for less than 1 year. Unsure of miles. The TT chip is set up for 92 octane 20deg/18deg 16-18# of boost. I'm honestly unsure of Reds specs. They came with the injectors when I bought them. Thanks! ----Jeremy
Bump to the seller...
I have a set of these same injectors. I will be selling when I upgrade my turbo. They are in a box right now as I bumped up to 83's. I went 10.81 with a little ole PT54 turbo at 24 Lbs boost with them. They work great.
From my understanding, the advantage to the low impedance injectors (requiring a modded ECM), is that they have more accruate and consistant fuel delivery. Hopefully I do not open a nasty can of worms - but some parts are worth the extra mods to run.
Good luck with the sale.
Mike
551bs inj
And with matching chips, I would be all over this-- only I have these already
I'm afraid I don't know much about modding the ECM. I guess I'll have to pass on this great deal...:frown:
You can buy one for $150-$200 off the board or FullThrottle sells them too.
Basically I priced all of this so cheap enough so someone could buy a modded ECM and this set up for the same price as a set of just 60lb injectors. So you'd basically have a modded ECM, TT chip and Reds chip for free.
He is totally correct on being a great price. With a modded ECM, you get advantage of better control of fuel delivery and more options of injectors in the future.
I do not know the seller, but just want to give some more info to think on.
Red at quad air is still modifying, I believe. That is who my ECM was done by.
Good luck to all,
Mike
Wow, I really cant believe I still have these. I figured at this price, they would have been gone in a second!! No biggie, I'm sure someone will need them eventually!
I don't even need or want them and thought about buying them at that $$$$$
