5x120 vs 5x120.65
ralphsmith_jr
Its a six
I know this will start an uproar with some however I need some advise from those of you with the experience. I know that 5x120 is a different lug pattern from our standard 5x120.65 however on some other forums people are running this set up on their cars without any problems at all. Is there anyone here in our forum running rims with this set up (5x120)? I am just trying to open the possibilities of more choices...Thanks in advance
some wheels will climb on no problem some won't. a friend put some BMW shnitzers on his Camaro no problem....some wheels won't be as easy and will require some enlarging of the hole but will be so minor that it should work....again its gonna depend on how the pattern is as you might just end up with damaged wheels. good luck.
on another note go to the junk yard and pick up some messed up 5x120 wheels for experimenting.
