60ft times w/ bfg drag
tom robison
ALL UP IN THEM GUTZ
what kind of 60 ft times are guys running with bfg drag radials and what suspension upgrads do you have?
BFG 275/50 on an 8 inch wheel set at 14psi cold with a pretty lengthy burnout
1.49 60 foot and 6.74 at 103. This was the best, most were in the low 1.51 range.
Front suspension was moroso trick springs and shocks set on 70/30
Stock rear springs with pass. air bag on 25psi. Boxed lower ca's with poly bushings and metco uppers with pinion angle set at 4 degrees
I always left on 7-10 psi off the foot brake+ e-brake. Stock rear sway bar and no front sway bar. I hated the air bags and would go with a good sway bar like the HR or Wolfe if you wanted consistency.
