6152 question...injectors and converter
grocerygetter
My Pat's converter goes to about 3100 on the foot brake...more on the transbrake.
I'm running 50# injectors.
Now I have a TE44...would this 6152 (.63 AR housing) spool fine on my set-up? I don't want some laggy junk for a car I mainly drive on the street. I know it will be fine at the track due to the t-brake.
Will I have enough injector? Plan on keeping it at mid 20s on boost or less.
One of the guys in our club runs a 6152 with a 3200 vig 5 disc and it spools pretty instant. Your 50's will be ok at boost levels you've indicated..
I think it will be a little laggy. I would keep the 44 if you want faster spool up. I have a GT32 on my TTA and it works awesome on the street and track. It spool instantly with a 2800 10" TC and runs 11's pretty easy at the track. I think it can go 11.50-60 at 25lbs. IMO, I would keep the 44. If you had heads/cam, then I would go with the 6152.
Look at my signature
I am extremely happy with mine and it hits hard and quick on the street.
GO with 6152 for sure , I used to have vary much the same combo with TE44 , upgraded to GT6152 .....yeeeee baby , you will like it , 6152 got ported inlet so it will spool up like crazy over TE44 , 50's will work ok' . Mototrons 60's would be the match with 6152 , that's my first experience !!!!:rolleyes:
