- Nov 30, 2009
Yes , 3-bolt exhaust inlet & 4-bolt outlet . The difference is the oil drain is threaded and the stock drain will not work . Mine is a -10 drain .you probably mentioned this elsewhere and i missed it, apologies in adv. Is the 0.85 AR housing on the Comp turbo a 3-bolt inlet and Buick compatible 4-bolt exhaust? GN1 DP with external waste gate?
