TURBOPOWERED68
David
- Jan 31, 2006
nice work dude.
Stock buick tank/pickup/pump done up with the usual hotwire
Chevelle 5/16" feed line used as the return
Used as much of the stock buick feedline as I could get off the buick (this includes from the engine, to the filter, and about 4 more feet of the 3/8" hardline) , the rest was supplimented with rubber (about 2ft)
Vent line is about 3 ft long and is fastened to the top of the rear end hump ( so its above the tank)
Good luck and ask more if needed!
I used the Chevelle straps actually, they are a bit loose though.
"Did you make a plate or mount fixture for the cap end behind the plate?"
Do you mean did I fix the neck to the car at all? If so then no. Ill tell you what man, filling this thing is a pain in the donkey. I have to hold the gas pump at half staff the whole time.
