Fuel vapor cannister replacement
garnetkid
I am going to replace my original cannister (long overdue) and would like some advice on an aftermarket replacement product. What do you recommend. thanks, Leon
Don't overthink it. Just get a parts store replacement. It's not a performance item, and any aftermarket unit is going to incur extra cost because you'll have to use something other than the factory rubber vacuum lines to hook it up.
it doesnt go bad , the fiberglass filter pad at bottom can get dirty , its just a can filled with active charcoal that absorbs gas tank fumes and then releases back to engine on decel (stock chip)
