robzombie
 - Oct 10, 2012
My motivation for the deeper pan is oil capacity. I've always used higher capacity oil pans on my V8's. Just made sense to me so I thought I would see what the TB community thought of it.
I thought your motivation was low oil pressure when hot from reading your original post.
If capacity is your motivation then by all means get one as long as you don't think ground clearance will be an issue. The stock pan is about 5 and 1/2" from pan rail to drain plug and the RJC is 7". Stock pan is about 1/2" from the bottom of A frame and RJC will go past it by about an inch depending on mounts and their condition.
Bottoming it out won't likely be an issue except in extreme situations.
