I have cut and pasted a description on this car with many details. It is also listed on V8 Buick and many members know the car.
Here are a couple pics posted and please click on the link for video and many other pics.
Mike
71’ BUICK SKYLARK
455 4spd
GS tribute
Original 66,000 mile 350 2 barrel AC car with 350 Automatic (now 69,000)
Now has GS hood, 71 GS grille
Sporting a new M20 4spd manual with new .038 over 455 built by Nick Servo
Auto to manual swap done correctly by Ivyland Collision in Pa.(Gran Sport Garage).
AC from engine compartment removed, under dash stuff still there.
Aftermarket quick ratio Power steering
Power disc brakes up front drums out back all new
All new front end, New Tubular CPP front upper & lower control arms with new KYB shocks.
1.25 Front sway bar and new Poly end links
New Tubular UMI lower rear control arms
New UMI rear sway bar
New UMI tubular control arms braces
New Metco Adjustable upper rear control arms
New KYB rear shocks
New 3.5 inch aluminum driveshaft by Precision driveshaft in Fl.
Newly rebuilt 8.5 rear with 3.73 gears built by Ken Gies Everyday performance
Brand New TA rear girdle cover installed
Weld Prostars all four corners 15x7 fronts with 15x8 rear.
All new stainless steel brake lines front and rear.
Newer carpet
Overall interior VERY clean and nice solid 8.5 out of 10 dash very nice condition could use rear package tray (faded)
Oil, water, temp gauge under dash, tach on column
Fuel gage mounted on cowl (easily removable)
Brand new door sill plates
Brand new rechromed front and rear bumpers from Tri- City plating
New gas tank, new ½ inch sending unit with -8 line ran along frame to new RobMC mechanical pump
Newly coated TA 1 7/8 headers 3.5” collectors to New Torch Tech 3” pipe to New 3” Walker Dynomax Turbo mufflers to New 3” TA tailpipes
G-Force aftermarket transmission cross member (very nice piece)
Metco drive shaft safety loop
New Fuel Tank with New RobMC half in sending unit
New Fuel lines installed!
New motor just installed & built by Gran Sport Garage ( Nick Serwo)
482HP & 537trq (9.5:1 compression) fully balanced/blueprinted ( all paper work)
$5300 in recent engine parts alone from Gessler
.038 Wiesco Pistons Moly rings
Block decked and line honed with plates
Bullet 288-92H cam (degreed)
Edelbrock Stage 1 Aluminum heads with level 2 porting by Greg Gessler
Stainless Steel 1.6 roller rockers
Dual groove hardened cam bearing
All new rod and main bearings ( rods all resized)
All new gaskets
Edelbrock Performer intake by Jim Wiese TSP polished coated with heat valley pan welded to bottom of intake.
GM Hydraulic lifters (GM-Delphi hardened face)
Deep extra court oil pan baffled with larger pickup.
Brand New TA front cover setup by Gessler.
MSD billet distributor
MDS 6AL box with rev limiter (hidden)
All billet pullies, alt, crank, water pump, power steering billet wire looms
Holley 830HP carb
Ken Bell polished valve covers.
RobMC fuel pump
Alumitech radiator (Brand New) with dual electric fans, one on a thermostatic control the other on a manual switch.
Brand New engine wire harness
Body:
New reproduction core support and passenger inner fender well all powder coated. Driver side inner fender solid and powder coated as well.
ALL NEW Body bushings installed on whole car!
Body is very solid. Paint very nice driver. Have one a few trophies. At some point both front fenders were replaced. Driver quarter looks to be replaced. Couple very small pin holes in truck I found when replacing fuel tank. All trim on the car is very nice! Brand new tail light lens. Rechromed front headlight bezels. Top in very good condition no peeling or bubbling
New Front windshield
Probably much more I am missing which is why I put in word file to add or change. I am about the 4th owner and have done all the mechanicals in my possession. I had a Wildcat Engines built 455 in the car for about 2000 miles that had many issues which is why the recent rebuild now. In the last year with the new motor, 4 speed conversion, exhaust, new powder coated front end all new body bushings etc.. In this past year I have spent over $20,000 alone (parts& labor done right!).
This car has been garaged for many years as proven by its condition. All the hard and expensive stuff is done new motor, new fuel system, new 4spd trans, new suspension front and rear, brakes, new exhaust, newer rear, new driveshaft, new core support, new inner fender well, all new body bushings. I am very meticulous about my cars condition and look. I have owned this car since early 06’ you will not find a car of this quality of parts and work at this price anywhere!
This car flat out flies and pulls hard through the gears but is also tame enough for short trips or long cruises and you don’t need to keep filling it up with race gas! Jump in a drive it anywhere for years to come. Handles VERY well and excellent ride quality at all speeds.
I have WAY over asking price into the car and have just lost some interest and have other projects that will keep me from this car. I have all the receipts for the work on this car.
$21,000
Please contact if truly serious about owning the car. Have many pictures and can take more.
Mike Clear
609-634-7798
michaelwclear@gmail.com
Mike
	71’ BUICK SKYLARK
455 4spd
GS tribute
New KYB rear shocks
Newer carpet
All new gaskets
Holley 830HP carb
RobMC fuel pump
Body:
$21,000
Mike Clear
609-634-7798
