8.5 rearend needed...
198gbody
need/looking for a 8.5 out of a hurst olds or grand national or a t-type.. can be open differential no gears no axles no differential.. dont really matter if its bent or need axle tubes in it all I need is the center section.. post on here or message me or call if you have one.. 251-232-0769
I can get you an 8.5" center by itself if you're interested. I can cut the tubes off or leave them on.:)
aslong as it fits a metric car I can use it.. bought one awhile back from a guy on here and had to replace both bent axle tubes so aslong as I get the right center section Im alright.. where are you located?
