82 Regal with stage II f/S
Status
Not open for further replies.
278.C.I.STAGE 2
82 Regal with stage II motor with a lot of extras, $19.500 Call for more details 1-905-419-0234 thank's.
This a 153 Block 30 over, , Rod length 6.20, bore size 4.030, 4 bolt caps, crank is 4340 forage 3.625 10/10 steel crank, Block was never hurt or damage, Custom JE piston, Heads are GN1 Aluminum un touch with 1.65 T&D Roller rockers, 206/212 roller cam, Stock timing chain cover, stock intake, 70mm dog house with 70mm throttle body, 83 lb injectors, 4" mass pipe, LS1 mass air 3 1/2", Turbo is PT 76 4" in let, 3" discharge, ATR headers 4 bolt flange, Fresh 200R4 with some CK performance parts in the transmission, Art Carr converter 3500 stall., Ford nine inch with 3.90 gears and 33 spline axles, Red Armstrong's double pumper, and a lot more.
Status
