Most of these Carburetors are intended for use with superchargers, and have a unique capability that allows their power valves to reference the intake Manifold vacuum below the supercharger. This allows the power valve to operate as it should, based off intake Manifold vacuum. A power valve provides further enrichment to the main metering system under load (low vacuum) conditions. Without this external referencing, the power valve would be "reading" the Supercharger boost pressure, which has no bearing on the engine load.
I dont know if these style of carbs can be used with turbos due to the nature at which they operate. theroreticly it should beable to operate properly as long as its used in a draw thru application.
I could guide you thru the modifactions to a holley for boost referencing if needed.
A.j.
P.S. Im jealous though, Ive been looking for an 83 hot air setup myself!
LOL
