parts for sale
intake 50.00
fuel rail 40.00
valve covers 30.00
a/c compresser 50.00
throttle bod with sensor and throttle bracket 50.00
mass air flow sensor 40.00
turbo heat shield 15.00
85 engine wiring harness 100.00
85 ecm 50.00
85 crank pulley best offer
coil pack 40.00
module 100.00
injector harness 35.00
turbo oil return tube 15.00
steel vaccum line for intake best offer
power steering pump and bracket 35.00
alt 45.00
up pipe from echaust to turbo (has been rapped with header wrap) 45.00
steel fuel line ti injector rail best offer
turbo oil feed line best offer
stock replacement 30lb injectors 150.00
7 setting poston chip for 30lb injectors 125.00
or 250.00 for injectors and chip
postons gn107t cam used 70.00
hot air headers and crossover pipe was told there postons best offer
8445 heads 100.00 for the set
83 turbo block 65.00
email is jimmys434@aol.com
thanks jim
intake 50.00
fuel rail 40.00
valve covers 30.00
85 ecm 50.00
coil pack 40.00
module 100.00
alt 45.00
thanks jim
