Hi,
A bunch of stuff is readily useable. I would say that you should be able to use about 75 % of your stuff on the new car. While it is unlikely that you will be able to use it all, I'm reasonably certain that a large percentage of the vehicle will be directly translatable. Things that come to mind are: most of the drivetrain, including the coveted 8.5 rear axle, the fabulous motor these hotair cars had, and the honest 200r4 trans, which is one of the best GM built.All in all, the car is a goldmine. DON'T sell the remnants. You will find lots of uses for the remaining stuff.
