T-TypeTurbo
- Aug 7, 2019
hello i recently purchased a 1984 buick rivera T Type. is this forum for regal owners only, were they just more popular? i know the 3.8L turbo was a cool engine so i went to look at the car, to my surprise it was front wheel drive.
[FONT=Roboto, -apple-system, BlinkMacSystemFont, Segoe UI, Oxygen, Ubuntu, Cantarell, Fira Sans, Droid Sans, Helvetica Neue, sans-serif] i had driven the car a bit to test then after a 150 mile trip the car started getting hot in the streets and i replaced cooling system [/FONT]successfully[FONT=Roboto, -apple-system, BlinkMacSystemFont, Segoe UI, Oxygen, Ubuntu, Cantarell, Fira Sans, Droid Sans, Helvetica Neue, sans-serif]. the thermostat gasket was leaking (only part my mechanic "fixed") so i replaced it and [/FONT]When i was burping the coolant the car ran great, then 3 hours later for no apparent reason its starts and then stalls.
I REPLACED:
( the old cork valve cover gaskets that leaked tons on oil onto the exhaust, coolant, thermostat , both temp sensors, water pump, radiator and cap, spark plugs, wires, air/ fuel/ oil filters, probably some other stuff too lol)
CAR CONDITON:
the car is stock, except the exhaust ( cool pipes that run down the side of the car under the door). IT had sat in the hot sun only starting every now and then to run for SEVEN YEARS so the paint it cracked and the rubber parts are crappy under the hood. there is a ridiculous amount of gunk built up on engine and engine bay lower parts ( radiator was leaking. ??).
the codes said MAP or BARO problem or wiring to the ecu from them, i replaced map sensor, it made no difference. where do i go from here? thanks!
I REPLACED:
CAR CONDITON:
