sean lawrence
- Jan 13, 2013
my 84 gn runs good and cranks up just fine. my issue is when you floor it takes off and starts building boost and starts pulling hard until you hit about 3/4 throttle and then it kind of bog down, if you let off the gas a little bit to 3/4 throttle or so then it starts running better and not bogging down but if you floor it at any speed it boggs at 3/4 throttle and up. it has ran like this since i bought the car a month ago. just installed a new 1987 gm ccci and conversion wiring kit and a borg warner coil pack and wires and delco plugs and 87 crankshaft sensor and harness. and now it runs exactly the same as bofore. i noticed when you put the 86-87 ccci and coil pack on the 84-85 gn people put the spark plug wires on the opposite side, like 1-3-5 would be at the front of the motor and 2-4-6 would be on the back with 84-85 gn. but when people put the 86-87 ccci and coil pack on the 84-85 they have 2-4-6 on the front and 1-3-5 on the back and thats how it was set up when i bought the car and it missed then and also ran like shit but it did drive from texas to alabama like that but when i got it home i put the spark plug wires on like the 84-85 gn 1-3-5 on front and 2-4-6 on the back and now it idle's good like that and runs good and builds good boost until you hit 3/4 throttle and it boggs until you let off a little. were as before i swaped the wires it ran like crap but it did run. so anyone had this problem or know what i should do? the engine is stock but it has headers and dual flowmasters and turbo tweak chip.
