parts
I dont now if you have the wires in door for it .You only need speckers and screws and brackets will be $21.00 shipped and lower door panels would be $75.00 shipped for the maroon panels.I dont have any pics. You will need new plastic push pins to fix the broken ones when you take the door panel off .You can take lower panel off by taking screws out of lower handel,armrest and behind that is two large screws and then pull off from bottom of door and then sides and you can see what is in the door for the speakers and you may have to run wires to radio or find a door harness .thanks
