84 gn turbo question
jay72chevy
Hi I am thinking on sending my turbo out and getting a ta33. Where do i get 36 lbs injectors and what else do i need to get. My car is stock, just need to know where to get the upgrades. Thanks
Stock injectors are 28 lbs and 30 lbs will work just as well. 36lb injectors will require a new chip which will open Pandoras' box. Do I upgrade to the 86/87 ECM? Is my fuel pump upgraded and hotwired? Why not spend the same amount and just get 42lb injectors? The only point here is that there are many things to consider and evaluate before you start spending alot of money. Ask away. Brad
looking for injectors that are less the 42 lbs..
Turbo tweak will program the chip to only use what is needed (such as 36 lbs injectors) if you go with the 42# injectors and then you will have room to grow vs buying bigger injectors again... my .02
