The past few weeks I've been replacing everything on this motor I can get my hands on.All the fluids,hoses,filters,vac lines,water pump,thermostat,plugs,belts,wires,02 sensor,TPS sensor,fuses,blah blah blah
O.K.- the questions
When you change the oil and filter you disconnect the orange wire and crank the engine 30-45 seconds to prime the oil system.Does the light in the dash turn off to let you know it's done?Mine did not.I disconnected the feed line to the turbo and cranked it over, no oil cometh out........
But, I can blow into it and it is not obstructed so I assume pump is bad???If the pump is bad and I have to change it, does the timing cover have to come off?
When the orange wire is disconnected, should the car start if you keep cranking it over?
In the hole in the dash where the radio should be there is a round connecter with a black wire and a gray wire going into it.What is it supposed to connect to??
Other than making sure the TPS,IAC,and idle are within the proper specs,is there a reset for the ECM or does it just recalibrate itself after disconnecting the battery?
Finally, the floor shift cable-does anyone have a p/n for it??Autozone,Oreilly's, Napa or other?
Thanks for all the help-Joel
O.K.- the questions
