I will tell yall the history of car first
Ok guy's I just recently bought this car from my uncle who had only driven the car about 100 miles in the last 10 years.My uncle bought it from the original owner in 1997 with 42,557 miles on it.
For what ever reason the original owner put a 12 gallon Fuel cell in the trunk
with a large inline can style fuel pump mounted under the trunk.
The car also has some aftermarket computer or what seems to be aftermarket that is Black in color,The injectors have been changed they say 37lb and they are aluminum color.
The guy also put an adjustable wastegate rod on the turbo and no Cat Conv.
When my uncle bought the car he said that it alway's idled ruff and that it took awile for it to warm up and even at 190 degree's it would still idle ruff.
How I ended up with the car is last month when he drove it the car blowed the intake gasket and he didn't want to fix it so he asked me if I wanted to buy it.
So I get the car bring it home start looking over were all the VAC lines and PCV lines go for memory of were they go,but some of the lines weren't hooked up it didn't even have the main VAC line hooked up it was blocked off I look at the break down yall have of the hose's and half the lines weren't even going were they were suppose to be going.
So I go and buy intake gasket, head gasket's, valve cover gasket's,and new VAC lines.
I start taking the top end apart and surprise on the drivers side head the right center head bolt had broke and was just laying on top of the head so the head gasket was blown good thing I decided to go on and do the head gaskets to.
So I debate on getting ARP head bolts,but decide I want to upgrade to some performance stuff later and I will buy them then. So I get the head bolt from my GM dealer.
I put the top end back together put the VAC lines were they are suppose to go the best I could tell according to the breakdown other than the waste gate lines I T'ed them into one line and hooked it up to the turbo.
I start it up and it up it purred like a kitten for 2 seconds then started to fumble I gave it some gas and it was still fumbling until the turbo spooled then it cleared up I let off gas it try's to die pat the gas rev till spool then let off it try's to die.
So I do this for about 5min thinking maybe it needs to warm up,but nothing changed.
No check engine lights came on,but it is a digital dash, but everything seems to work on it.
I know it is running really rich the exhaust fumes are strong.
I do not have away to read the computer so that is out of the question.
I also noticed that I did not see a map sensor anywhere under the hood.
And the Vac Can isn't hooked up.
Also I would like to add I do not have the PCV line that comes out of the passenger side of the intake hooked up cause I didn't think it would bother the engine plus I couldn't tell how they went in the breakdown pic's.
Please someone if you have any suggestions on how to help me get this car running right I will be gratefull.
Please please help me so when I get home today I will have some direction to go with fixing the problem.
Thanks,
Cliff
Thanks,
Cliff
