Oct 20, 2010 #1 S STACYFAST New Member Joined Oct 20, 2010 Messages 1 will the crank sensor from a 87 work,i installed i cut 84 plug and put 87 on installed to block set no fire.
Oct 20, 2010 #2 R RegalT-type85 New Member Joined Jan 23, 2010 Messages 934 You mean you Cut the connetion and splice in the 87 sensor? Do you have any fire? what else is going on, check engine light on/blinking? Fuel PSI?
Oct 20, 2010 #3 T- Type Tim Vice Chairman Joined Jul 8, 2001 Messages 2,158 i'm almost certain the sensor is different
Oct 20, 2010 #4 H hcox10 New Member Joined Jan 27, 2004 Messages 119 wont start hi, casper electronics has a crank sensor for '84 T-Type. Harold
