- Jan 21, 2007
I thought I would share with you some of the scanning technology we use where I work. We needed demonstration parts for a show and tell event and they asked me if it would be any problem using my 231 head (It is small in size and has some intricate shapes). Sounded good to me
We used a Steinbichler T-Scan. The one picture is the Scanner the other is the Tracker. It uses a form of GPS to know where the scanner is at all times. The accuracy is really really good (.0002MM).
The first part pictures are the stock head painted primer for the show but it does not need to be painted for this scanner to work like some systems. The first scan picture shows multiple colors for all the overlapping scans that were performed. The final pictures show the best fit of the data creating the point cloud. This data is used to create the final Surfaces and Geometry needed for creating a Parametric Model.
The point cloud data, as good as it looks, is not a Parametric Model so you cannot work from it(like creating a cutter path) you need to do additional work for that.
You could take this data and compare it to data you get from another head and see the differences. Like comparing this to a reworked head (Champion Irons) or even see the differences from chamber to chamber.
Hope you enjoyed this ….rick
