85 gn
Ramco 24
Up for sale: 85 GN. I just don't have the time to enjoy it anymore. Here is the low down, 113,000 miles lots of new parts, 87 look a-like. t-tops, digital dash, new tires, pretty clean. Please see the youtube video below. The car does run a rough. I have replaced the plugs and wires this year but, it did not clear it up.
youtube.com/watch?v=MEk84EcAk0U
The Good!
New plugs and wires
Newer battery
Newer Walbro 304 fuel pump
New coil pack
New alternator
Inter-cooler
The turbo has been opened up and I installed an adjustable waste gate actuator.
Failry nice interior, with new upper door panels and new window motors.
New ECM
Turbo Tweak chip
New crank and can sensors
New rear end gears (not posi)
New water pump
New stereo and Dash speakers
The Bad:
rear main seal leaks
small rust spots starting on both doors (see in video)
Has a miss in the motor but, does run. Once the mis started I did trun down the boost.
I did remove the A/C but I do have all of the parts to put it back.
Asking $6000. Located in Wisconsin.
DONT SHUT THE DOOR BY THE GLASS!!!!!!!:eek: I hate that!:biggrin:
Do you know where the "miss" is or I should say, what is causing it? Have you checked the cam to see if it's flat?
How much boost were you running when it started to "miss"?
I have someone that may be interested in the car but I want to know whats wrong with the motor before I have him spend $6K on a non posi hot air with a miss, thats a lot of $$$. We are in Iowa, what part of Wisconsin are you from?
