.85 precision exhaust housing for S trimm.
forcedfedv6
Banned
Looking for an .85 precision housing for an S trimm wheel for a .70 turbonetics single BB Turbo, let me know location and how much..
The S trim does exist, it is a new generation Turbonetics exhaust wheel F1-S trim. I have one with a .85 3-bolt housing on my car.
Datar
Wow... that's news to me. We were always told that the wheel was too big to fit in the 3 bolt. Can you measure across the opening? Maybe it's cut down?
Should be 75mm across i believe.
You are correct regarding the precision GTS wheel which is way bigger than this one. This version (F1-Strim) measures out to 3.112, precisions equivalent which is the same exact wheel is called the HPQ. This wheel has a slighty taller and wider tip height than the old GTQ which requires the 3 bolt housing to be modified from the inside to fit the wider wheel.
Datar
housing
i have a precision but i dont know if it will fit your turbo. its in the for sale forum with pics and measurements. make offer
Probably similar to the HPQ which is a GTS wheel that has been cut down
