'85 to '86/'87 Setup- School Me
eightyfivegn
Interested in maybe doing the swap to a 86/87 setup. What does it take? I have access to a lift, tools and some knowledge...just want to know what I am getting myself in to.
Convert HA car to IC car- Conversion parts list
All front engine accessory brackets with pulleys and belt tensioner
Complete intake with all sensors
1987 ignition module, coil, and all wiring for it
1987 hard metal heater lines on top of intake
1987 throttle body
1987 throttle cable
1987 MAF with air intake tube and air box
1987 detent cable
Downpipe
1987 catalytic converter
Drivers side oil fill neck
Passenger side header
Passenger side valve cover with vent tube
1987 transmission dipstick and tube
1987 heater core
1987 alternator, ac compressor, power steering pump with remote reservoir
A/C lines
1987 radiator hold down
1987 radiator
Oil cooler lines
Main engine wiring harness
1987 fuel lines
Intercooler with all brackets
Intercooler fan
Intercooler piping
Intercooler scoop
1987 air dams and deflector
1987 Turbo
Turbo brackets and heat shield
Turbo oil feed and return lines
Electric fans
All hardware including any nuts, bolts, or fasteners needed
http://www.turbobuick.com/forums/threads/need-help-with-85-to-87-conversion.250756/
http://www.turbobuick.com/forums/threads/ha-ic-conversion-parts-list-help.318759/
Go to the Junkyard donor section and in the "sticky" section at the top of the page you will find a Junkyard donor
pdf... download it to your computer and read all the related links- you'll be glad you did ;)
