86/87 bottom end
intercooled 85
looking for a drop and go 86/87 bottom end. with all internals could be stock. im fine with that. my bottom end took a crap on me and the main bearings went. local to the pa area is preferred. thank you.
no matter what installing a new bottom end will require a machine shop. block has to be line bored to new crank. i have a std std crank for 250 shipped. its from original 87 gn.
I have a 1985 hot air long block for sale with 78K miles for $500 in CT 06492
Its not a 109 block but has the turbo crank and pistons from the factory just like the 86-87
you will need to drill out the turbo oil return line
I've got a 60k longblock here in CT that's never been opened. You can have it for $1600. I can update the timing chain and rear seal for extra. I'll pull the pan/caps in front of you so you see exactly what you're getting. No junk
I got a stock rotating assembly that came out of running, no knocking car. I will sale for 400 dollars or best offer pistons, rods, crank, damper, flexplate. I am located in south jersey
