camaro75racer
- Jan 12, 2005
Ok, finally got everything to swap the ecm over from the 85 to the 86/87 and changed everything over.(MAT install kit and sensor,87 ecm,87 MAF, and both chips one of which is a Thrasher 92 chip) Once everything was changed over the car idled rough and gave no codes. My scanner (one of the ACTRON's) read that it was constantly lean instead of cycling between LEAN/RICH like it's supposed to. After a couple minutes the O2's drop to zero and stay there. After this the car begins to cut out at 2000rpm to the point of the motor dying. Whats up with this? Swapped the computers back out and car runs great with 85 ecm and 87 MAF installed and O2's are normal. Please help.
Dale
Dale
