This may sound dumb, but is it possible to put an 86/87 intake, turbo, intercooler, etc... on a hotair. I heard there is a difference in the block,,, and oiling. But would this work.
everything will bolt on to the hot air blocks the only thing u will have to do is tap a hole some where for the oil return line since on the hot air there located on the intake. i would tap a hole into the side of the front timming cover.
thanx. Do you know if I'll be able to use a stock 86/87 oil drain tube, or will I have to modify something. And is there a good place in the timing cover to tap into.
