86/87 Interior, Exterior, Engine & Brake Parts for Sale
87 WE2
Engine Parts:
Kirbans reproduction PVC & Map sensor metal vac lines for the vac pod $18 new in the bag.
THERMOSTAT HOUSEING, OK SHAPE $5
NEW 195 DEGREE THERMOSTAT $5
K&N Air Filter for Stock Air Box $20
CAM SENSOR DRIVE (MAKES NOISE, NEEDS SHIMS) NO CAP $35
WORKING EGR VALVE (NON AC DELCO) $ MAKE OFFER
LOW MILAGE - KNOWN GOOD EGR SILONIDE $40
NEW IN BAG, AC DELCO 87' RUBBER OIL PAN GASKET $25
HEAVY DUTY INTERCOOLER TO TURBO COMPRESSOR HOSE NEW 10 MILES ON IT WENT TO BIG NECK INTERCOOLER $10
Stock Turbo Oil feed line $5
Transmission Parts:
NICE STOCK 200 R4 TRANS PAN PILOT HOLE DRILLED FOR ATR'S DRAIN PLUG $15
Brakes:
VACUUM BOOSTER W/ CHECK VALVE (Booster does not hold good vacume, good for core only) $15
MASTER CYLINDER ASSEMBLY for Vacume Breaks (New, tested good) ALL HARDWARE/INSTRUCTIONS INCLUDED $45
BRAKE PEDAL ASSEMBLY for vacume breaks $15
Exterior Parts:
CHROME WHEEL WELL MOULDING - DRIVER SIDE FRONT $15
CHROME WHEEL WELL MOULDING - PASSENGER SIDE FRONT $15
CHROME FRONT FENDER CORNERING LIGHTS (PAIR) $45 obo
PAIR OF DOOR VENTS $10
2 REGAL EMBLEMS GOOD FOR DAILY DRIVER $5 EACH
1 BUICK TRUNK EMBLEM GOOD FOR DAILY DRIVER $25
GN TRUNK DECK LATCH $15 (No Lock)
GN TRUNK DECK LIGHT ASSEMBLY $10
Interior Parts:
87 T STEERING WHEEL CENTER MEDALION NEAR MINT $8
Brown Horn Pad $15
Pics are available upon request.......................Thanks for looking.
