86/87 Turbo Buicks Parts, New & Used
tbirdv6
New Parts:
Napa (Echlin)Crank Sensor (in the box) make offer
A/C pulley (brand new) for GM compressor-maKE OFFER
Turbo-to-Intercooler Hose
new, goes from 3" to 2.5" & includes stainless T clamps (2)$29
Also have another one new w/o the clamps for $19
USED PARTS:
Stock Pistons (standard) w/wrist pins-$60 (less than 500 miles)
Oil Pan-20 bolt- $30
Fuel Rail- $40 (mint)
Fuel Injector Harness-$40 (mint)
Heater Line Assembly-$40
Double Roller Timing Chain Set- $40
Top dash plate-Gray, repaired small crack-looks almost perfect-$65 shipped
200r4 transmission pan-$20
Accessory Bracket-$75
charcoal canister-$30
stock cam,stock push rods,stock rocker shafts/rockers-all in great shape-make offer
Gas tank (baffled) no sender-great condition-make offer
TV Cable(rachet type,adjusts shift points)
I my spare for sale(used), this is the cable that goes from tranny to Throttle Body Linkage & has the rachet adjustment-$25
Alternator-stock, $65
Stock Rear Sway Bar- make offer
4 GN center caps-$55 shipped
Rear Black GN Bumper w/Aluminum Support & extra Bumper Strip Make Offer
i will take the pistons-
Just to make sure, these are GM factory pistons and not hypers correct?
thanks
BW
ps how many miles on the timing chain? any stretch? is it a cloytes?
BW
I assume there is nothing wrong with the pistons correct?
No scratches on the sides?
why did you dissassemble the engine with so little mileage?
Chain is for standard line bore correct?
BW
pics are worth 1000 words, thank you.
why did you disassemble the engine with such a short life?
i need to know if these are perfect and usable
BW
parts
Is the bumper strip new? Is it all black? If yes to both, would you take $50 shipped?
Answers to the above:
Tore motor apart to find out why low oil pressure, already had another short block assembled-just did a swap, found out cam bearing failure-sent pics
bumper strip is used & on a 1-10, probally an 8
No seat belts available
BW
Maybe you didnt see my questions?
the email you sent me didnt have the attachment, so i couldnt open it up.
BW
I assume there is nothing wrong with the pistons correct?CORRECT
No scratches on the sides? NO
Chain is for standard line bore correct?YES
Would like to know some info on gas tank. showing any rust, miles on car and such.
Also, where you located? Curious of shipping costs on it.
Mine is leaking badly.....let me know
paypal of 115.00 sent to you for the turbo pistons and timing chain.
thanks
BW
