86 gn 61k hard top Illinois
kurt86
I have a nice 86 gn with tons of new parts. I have to many projects right now and no more space . Motor was gone through and new bearings and all new gaskets installed early this year. Digital dash 61K orginal miles $13,000 takes it. parts list include:
*3" mandrel bent dual exhaust
*3" dyno max high flow mufflers
*3" mandrel bent jet hotted dual tail pipes
*200R4 bowler roller race transmission with deep extra capacity alum. pan
* Front mount trans cooler-6 stainless steal hose all black - an fittings
*10 inch vigilante 3200 stall converter
* TCI race shifter cable
*160 degree thermostate with billet alum. housing
*Walbro 340 fuel pump/with hot wire kit
*50 # MSD flow matched race injectors
*Billet adjustable fuel pressure regulator
* adjustable waste gate 38 mm turbonetics delta gate
* New coil pack/ full throtle and speed
*New magnacore 8 mm wires
* vacuum brake conversion
* KYB shocks
* billet oil fill tube/ full throtle and speed
* Optima battery red top
* Alky control injection system
* New GN1 performance monster 3" polished front mount intercooler
*GEN2 MAF translator/ full throtle and speed
* Extender chip full throtle and speed for 50lb injectors
*TE44 turbo 3" in 2.5" out
* Gages/ boost /oil/ water temp/knock
* Newer tires
* Billet oil filter relocation kit with high flow KN oil filter
* All lubricants royal purple synthetic in trans-10w30 in engine-$300 worth
* New alum. radiator
* New alternator
* RJC power plate
*ZO6 MAF sensor 3.75" 85mm
*ATR 3" mild steel external waste gate down pipe
* 3" dump tube
* Many new parts also go with car not installed yet
*New in box COMP 916 valve springs, locks, vitton valve seals,rear airbag
* New front air dahms
I'm trying to put up pictures but am not having luck, if you want to see them please let me know. Thanks!
