1986 Buick Grand National (T-tops), with 71,000 original miles. Car is in good shape but it does however need front and rear bumper fillers, and has some rust on the lower driver side door. It also needs a driver seat switch to adjust the seat forward and back (Its perfect if your 5'8''to5'9''). The car does not have a radio i deleted it for autometer oil, water, and boost gauges. The modifications are as follows.
TE-44 turbo with adjustable boost valve(bleeder type), K&N cold air kit, 3"THDownPipe w/3''dump you can open or close, Alky kit(alkycontrol), TT Alky chip, 42lb injectors, Walboro 340 hotwired fuel pump, Accufab adjustable fuel pressure regulator, Powerlogger, and Scanmaster. Iv also converted the car to vacuum brakes and swapped the ac over to 134 and it works great. Im asking 12,000.
