LC2 ROD
The original LC2 ROD
- Nov 4, 2002
I tried eBay and ended up with a bogus bidder and bogus eBay email scams.
So I'll try here before going back to eBay.
86 GN T-tops, running driving project car.
Clean title and current registration.
Approx 130,000 miles, had a dash replaced, I have paperwork supporting.
Car drives strong and transmission shifts firm, has 3.73 Richmond rear end gears.
Has stock turbo and injectors, has a fuel pump hot wire kit.
Overall a solid car that needs work.
I bought it as project for myself back in 2004 and it has sat in my dry shop since then.
First thing that needs addressing is the engine knock, before it could be a daily driver.
Left side exhaust manifolds leaks, probably cracked, (typical).
Has great oil pressure 25psi idle, and 50psi 2500rpm both with warm engine.
Has the typical surface rust on the suspension.
Minor rust issue at T-top area.
Floors, rockers, quarters, doors, fenders, trunk and hood all look very solid.
Paint has delamination, cracks, and fading, looks ok as a driver, but could use a paint.
Interior is decent, seats have some wear, needs a headliner (easy fix)
The digital dash does not light up, I checked the wiring ok, Caspers can rebuild them.
Has stock size tires in very good condition, about 90%.
Ill post more pics this Sat.
$ 5,400.00 US obo , NO TRADES.
PM me, (or start a conversation )
