Dan SS2471
- Dec 12, 2008
Thinning the herd and also looking to start a new TB project so I'm selling the GN to make some room. Car is located in NJ.
Here's the scoop:
Engine (rebuilt with the following. Has about 6,500-7k on the clock now):
- .020 forged JE pistons
- 204/214 flat tappet cam
- ported stock heads (Brosnonian) held on with ARP bolts and Cometics.
Re-torqued a couple of months / less than 500 miles ago.
- steel mains
- double roller timing set
other good stuff:
- Precision 6776 BB 'S' cover - March 2010
- Precision SLIC - March 2010
- Razor's Alky - March 2011
- 60# mototrons.
- hotwired Walbro 340
- 3" LT1 MAF w / trnsltr
- TT chip - non-Alky...Alky chip included
- 160* t-stat with billet neck
- Caspers cam sensor cap
- 3" ATR downpipe
- Turbonetics Evolution wastegate with bleeder under the hood (RJC boost
controller included as well)
- test pipe with cutout
- Hooker 2.5" catback
Trans:
- Rebuilt 200 By Michael's Trans - all billet parts - built for high 10s -has about 20 passes on it and overall about 2,000 miles. Pro Torque 3200 LU. Done in March 2009.
- loop
- trans cooler
Monitoring:
- Scanmaster 2.1
- Casper's Knock / Autometer Boost (30#) pillar gauges
- Autometer Oil pressure / Water temp console gauges
- Comes with Directscan / laptop and modded ECM.
Suspension:
About 6,500 - 7,000 miles
-Savitske Classic and Custom Stage 2 Street Comp with lightweight adjustable upper a-arms
-Eibach springs
-Koni adjustable shocks
-completely rebuilt f/e with polygraphite bushings and Global West adjuster sleeves and Del-a-lum lower a-arm bushings
-front frame braces (F-41 braces)
-rear seat braces
-1" Spohn rear sway bar.
-lowered about 3" front, 1.5" rear.
- rebuilt G80 rear
Misc:
- All fillers are fiberglass. Replaced new in July 2009.
- Running 26" MTs - 65 - 70% tread
- a/c blows ICE COLD
- F-body aluminum radiator
- Converted to vacuum brake system
- aluminum rear drum brakes with sticky shoes.
- p/w, pdl, tilt wheel
- power driver's seat
- SonyCD player
- buickgn.com billet shifter handle
Needs:
- driver's door lower hinge. I replaced the pins...didn't do the job. Door closes ok but is a little sloppy.
- paint and ding repair. definite 20 footer.
- c-clip elims, beefy u-joints and axles if you wanna turn up the boost and be really safe.
Chassis has 136,283 miles. Carfax is clean. I'd give the interior a 7.5 - 8 outta 10. Small tear on the driver's seat. Minor surface rust on the bottom of the doors.
Overall the car is turnkey. Runs and drives very well. I've gone on 300 mile road trips without issue. Cruise it around town or drive it down the quarter. It's setup for both. I've made about 20 passes on it in it's various stages of upgrading and have had no issues with it. It's gone a best of 11.65 @ 114 with a 1.6 60'. 21#s of boost running rich and low timing. Turn up the boost and play with the fuel and timing and you probably have a low 11 / high 10 second pass with all the supporting mods (but no roll bar). It's built for it.
I paid 10k for the car in '09 and have close to 8k in it in upgrades. Asking $14,000 OBO. Not looking for trades.
Have plenty of pics available or can take on request. Here are a few.
Here's the scoop:
- steel mains
other good stuff:
- 60# mototrons.
- 3" ATR downpipe
Trans:
- loop
- trans cooler
Monitoring:
- Scanmaster 2.1
Suspension:
-Eibach springs
-rear seat braces
- rebuilt G80 rear
Misc:
- SonyCD player
Needs:
