86 White T-Type 10 sec. Street car.
86 Buick regal T-type.
White T-Top car.
Maroon Interior.
Fiber Glass Hood and front bumper.
87 Grill (only because they look better).
Car is from GA. NO RUST! Solid car!
Stock block and heads,
206/206 Cam and lifters,
Roller timing Chain,
65mm Throttle body,
3.5" Mass air meter,
4" big Mouth Cold air with 9" K&N Filter in Drives Front,
4" mass air pipe,
60lb Inj.,
te45a Turbo (Good for mid to low 10's),
3.5" Down Pipe with external waistgate,
4" Single shot exaust!,
BRAND NEW! 200R4 trans with trans Brake (Brian Hoffer on the board did it),
BRAND NEW! Art Carr 9" 3500 Non Lock up converter,
Brand NEW! Moser 30 spline Axles,
BRAND NEW! Auburn Locker,
Weld Pro Star wheels (Rear 15X8 Fronts are BRAND NEW 15x3.5" wide),
BRAND NEW 265/15 Front tires,
Hoosier Quick time pro 28X11.5X15 rear tires,
6 Point cage,
RJC Power Plate,
Modded Upper Dog house on intake to flow more air,
PTE Front mount intercooler,
Alky Control Alky system,
Auto Meter water, oil, and boost gauges,
Trubo Tweek Chip,
Tall Valve covers,
A/C removed and Mr Heater heat system installed .
UMI Double ajustable upper contol arms,
2 air bags in rear,
UMI Solid lower control arms,
Lakewood 90/10's in front,
Comp Engineering adj. shocks on rear (set at 50/50 now),
New body mounts,
New door weather stripping,
New T-top weather stripping ,
Car is from Ga. NO RUST! Solid car!
Car has clean car fax no accidents!!!
Frame is straight,
2 minior paint flaws one is a quarter sized dent in the pasanger side door the other is a run or sag in the paint when the guy I got the car from re-did the car and it has now cracked. Cant be seen in the photos and most people dont ever notice either one.
Bottom of car is rock guarded with White Rhino type liner so you can chip the paint!
Motor has around 20,000 since redone in 2005, Stock (Standard crank didn't need to be turned) Crank, Hyper Pistons, and Stock rods,
100lbs. Springs on valves.
She has a 10.50 or faster in her with a little more tuning. Best time out of her is 10.91 at 123 off the foot brake, without using trans brake that pass!
Car hooks hard and goes straight!
Im asking $13,500. o.b.o. Serious only please! This is a early spring price.
Thanks for looking. Bob, 810-360-6255
White T-Top car.
Maroon Interior.
65mm Throttle body,
4" mass air pipe,
60lb Inj.,
6 Point cage,
RJC Power Plate,
Trubo Tweek Chip,
Tall Valve covers,
2 air bags in rear,
New body mounts,
Frame is straight,
