Have an 87 gn, had some issues with a tps sensor 4 years ago, had it replaced and set.
Afterwards I couldn't even keep it straight it ran so good.
the boss took it out for a couple of rips, and then it all started.
the car was leaving like a smoke screen of white and the raw fuel would burn your eyes at 50 feet.
not antifreeze! we have been changing parts and scratching our heads for 4 years now and cant get it up and running. it will foul a set of plugs off in 10-15 min, the back right hole is always sopping wet.
we have just recently put in a rebuilt turbo, ecm, map, mass air, fuel pressure regulator, and on and on.
last night io got it running and not smoking, not sure what I did. took it for a rip today and now when the turbo should kick it backfires and pops and the smoke starts rolling , when you let off its good, at idle it revs up fine idles good, but you cant give her at all as soon as it starts to build boost its a smoke show again.
