Found another car I want so I'm sellimg my 87 Dk. Met. Blue Turbo T. Car has no rust at all on it. Could use paint.Hard top car. Int. is very nice with a small hole on the driver seat on the side. The size of a pencile eraser.Tinted windows. Od shows 50k plus. Fresh engine(standard bore) with turbo crank, rods, pistions. Has ARP main studs, APR head bolts. REEDS 205/210 cam Fresh timing chain, front cover. Heads are fresh 8445's with 100lbs. springs, and HD rocker shafts. Trans is also a fresh Race trans with Brake. New PATS 2800 stall L/U converter. Mease sheetmetal Plenum, Polished 58mm TB, 009's with 2 TT chips, ATR double pumper fuel pump, Billet adj. fuel reg., Polished TE44 with /.63 precesion ex. housing, stock IC, Mease 3' SS DP, All the little stuff, fuel guage, 10mm wires,drive shaft loop, 4 core Rad., Turbo saver, Boost/knock/water/oil guages. New brakes all around, lowering springs, new Bilsteins shock in rear, air bags, Koni shocks up front. GTA wheels with brand new tires, MT DRs in rear, and Ventus HR2's up front. Rear has 3.90 gear, Moser axles. Thats all I can think of for now. All it really needs is paint and I do not have a exhaust on it now, just running through the DP. Sounds better this way!! Have pics to send. Only reason I want to sell is I found another car, if It doesn't sell I have a fresh car. Asking $7600.00 OBO Email if you have any questions. I also have pics of the engine build. Have some extras for the car also, new front bumper fillers, window felts and some other stuff.
