theman1990
- May 29, 2024
Incorrect (b/c I'm new to standalone stuff...) The XFI REPLACES the factory ECU completely. I didn't know this until I pulled the kick panel to get the ECU model and found the XFI. The few electronic tune stuff I have ever used still utilized factory ECU so I assumed this did, too. My mistakeYou should have the FAST program to work on this car with, even if there's no AC issue.
No reason your LT, assuming it's not DOS based, can't load that program.
Before you do that, determine if the ac relay is even wired into the FAST.
From what I gather, the stock ecm is still in use and the FAST is on the engine. Y/N?
