Sep 11, 2019 #1 D dlebel New Member Joined Sep 11, 2019 Messages 1 Hello All, I just purchased a 1987 GN and I am getting the following error codes 24 & 31. Is this anything that I should be concerned with? Thank you in advance! Dave
Sep 11, 2019 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,019 Depends upon the modifications, post up everything you know about the car. Updated instrumentation? or wastegate control?
Sep 11, 2019 #3 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 The 21 may be a misadjusted tps,. The 31 is likely an unplugged wastegate solenoid Sent from my Pixel 2 using Tapatalk
Sep 11, 2019 #4 grass doctor Dream Catcher TurboBuick.Com Supporter! Joined Sep 21, 2018 Messages 2,777 Malfunction Codes Code Number Description 12Normal, no crankshaft pulses when engine not running13O2 sensor14Coolant temp sensor high15Coolant temp sensor low21TPS sensor high22TPS sensor low23Air temp sensor low24Vehicle speed sensor25Air temp sensor high31Wastegate solenoid32EGR33MAF sensor signal high34MAF sensor signal low41Cam sensor42EST circuit failure (ignition module to ECM)43ESC circuit failure (knock sensor module)44Oxygen sensor lean45Oxygen sensor rich51Prom error (chip or socket)52Cal-pak error (small chip by prom)55ADU error (bad ECM)
Sep 11, 2019 #6 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 Yeah, I looked at it cross-eyed.... Code 24 is vss. No big deal. Can happen from braketorquing or it could be a bad vss. Sent from my Pixel 2 using Tapatalk
Sep 11, 2019 #7 grass doctor Dream Catcher TurboBuick.Com Supporter! Joined Sep 21, 2018 Messages 2,777 I guess I should stop brake torquing then
