87 GN part out complete 10 sec car
Does it happen to have an aluminum drive shaft?
Is it going as a roller or are there fancy suspension pieces?
Can go as a roller. Clean title dashboard still in it 2500.reat is now 7.5 Only suspension mods were Southside lower bars
I have the quarter I need but was looking to scoop up some suspension if it gets to that. Might even be interested in a rolling frame without body if you get that far. Location?
Mid-car Exhaust hanger with rubber strap?
Analog Fuel sender?
Underhood light assembly?
What Exhaust is that? If it’s ATR I’m in??
how much for the following:
* Front mount IC with pipes?
* Underhood light fixture?
* Hood mounted FP gauge and everything need to mount/install/use (hose, schrader valve, fittings)?
* Mid-car exhaust hanger with rubber strap?
* Knock sensor?
* Coolant Temp gauge with sender?
Thank you.
