SignUp Now!I think the connector is different. The Fiero uses a square connector and it mounts in a slightly different location. I just transfer the wires from my old fan. I don't remember which year/motor the correct fan for our cars comes on. A lot of Fiero's use the standard small round motor.Is the fan from a fiero exactly the same? Same plug and mounting locations etc etc?
I'll take it I'm in ca 94590I have a stock elec fan from my GN that I upgraded to dual, pay shipping and you can have it, if it helps you out. Shipping from Vegas to you. It was working great three weeks ago prior to the upgrade, should work just fine for ya!!
One thing I noticed with these fans is that they draw ALOT of power. So much power that the OEM plug actually started melting because the stock ground is not big enough to support them. I upgraded the ground to heavier wire and havent had an issue thus far.
