SignUp Now!Most everyone will recommend an alcohol injection kit.
There are several performance mods that can be done fairly easy. You also need to concentrate on your suspension to make it hook.
Remove the heated coolant that feeds the bottom of the Throttle Body
Install a 160 degree thermostat
Either purchase or design your own fresh air intake. I use an AFE Pro-Guard 7 open element type of air filter attached to the MAF wedged underneath my A/C lines
Purchase a Turbo Tweek chip & the required adjustable fuel pressure regulator
There is more that can be done of course. You need to buy a ScanMaster at the very minimum so you can monitor knock retard, etc. Do many searches & read all that you can from this forum. Perform the "Spring Cleaning". http://www.gnttype.org/maint/basics.html
That should get you started.
~JM~
Not trying to hi-jack the thread, but I have a question on one of your recommendations. It may also help the OP.
You say to attach the air filter directly to the MAF. I'm assuming you're using a stock MAF. What did you do with the ATS? I tried this over the weekend (only with filter attached to the 90* elbow that has the ATS in it), and it didn't work well. Got weird readings from the SM on O2's (like 011 at WOT), and power was WAY down at WOT. Sounded cool, though!
I tried it your way first with the filter directly on the MAF, but didn't consider the ATS until I got a mal code 23 on the SM.
