Adding info on the car:
I am not interested in trades. I'll respond to replies through the Craigslist ad with phone numbers and I will check this listing as often as possible.
I have owned since 1994. Always used Mobil 1 synthetic, Have all maintenance records. Runs strong with 187,000 miles. The car needs some cosmetic work which I have accounted for in the low price.
New Hooker Cat back exhaust with high flow cat
Reinforced Driver side header
Vacuum brake conversion
Coyles double row timing chain
Melling high volume oil pump
Caspers high volume fuel pump
Hot wired fuel pump
Remote starter solenoid
Cold air intake with K&N cone filter
Boxed in intercooler shroud
All front body braces installed
Rear trunk body braces
Heavy duty rear sway bar
Tires good
Transmission rebuilt by Don Robichard racing
New battery last year
Oil pressure, water temp & boost gages
Knock detector
Laptop with WinALDL
Headliner and visors restored by Alan's in Tiverton, RI
New shift cable
Replaced Throttle body seals
New Transmission lines
Lots of spare parts including: Intercooler, Turbo core, Steering box, A/C condenser, Cat converter test pipe, A/C delete pulley, injectors.
Thanks,
Bob
