87 Grand national rearend
cavscout_32
as the title says i have a rearend from a 87 gn it has posi and the 3.73. I had it in my 1982 monte carlo. Parting out the car needs to go.
GN's come with a 3.42 rear gear and the Cutlass' come with a 3.73 rear gear. Do you kow for sure this rear is a 3.73 rear gear? Where are you located and how much? Thanks
Post some pics. Most of the Montes came with 7.5" 3.08 or 3.73....right??
read the thread again..This time very slow.."I have a rear end from a 87 gn"..
"I had it in my 82 monte carlo"..see how easy that was!!!;)
note:just wanted to clear any confusion...
although a junior member with 1 post would be reason for caution.. detailed pictures with a little more info and a paypal address would help your sale..hope this helps..good luck..
i am located in hastings nebraska. i should also mention that i have the driveshaft also. im taking offers no low ballers plz. you know what these things are worth thnx. if you have any questions pm me. I have this rearend on other websites too so i dont know how long i'll have it.
I am 1.5 hours from you. Is it a 3.42 GN gear or 3.73 Cutlass gears?
its a G80 rearend. if that means anything to ya. if you wana talk more in depth call or txt me 402-469-5556.
No need to be a d**k....I DID read the thread, I know he had it in his 82 Monte, i was asking for pics to verify it indeed was an 8.5 and NOT a 7.5...:rolleyes:
[/IMG]
as you can see i the pic the bottom of the pumpkin has triangle shaped tabs instead of the vampire fangs of a 7.5in.
G80 is the RPO code for posi in a GN. If its a stock rear then it should be 3.42 gears.
That's correct....the RPO for a posi is G80...the RPO for 3.42 gears is GU6.....for the Buick :wink: The only way to tell the gear ratio is to: 1) pull the cover and count the teeth, or 2) pull the axle housing code stamped on front of the pass side axle tube. That will tell you the gear ratio...if you have the book with all the codes for that model year. ;)
