Silver with chrome trim, maroon interior. This car runs and drives like new, and is in great shape inside and out. This is a very nice, SOLID, well preserved car. I have the window sticker, as well as a reproduction laminated version. The car looks amazing when the sun shines on it!!!
I like to get this stuff out of the way early, so there are no questions as to "what is wrong".... So here it is.... No rust anywhere. The car has had a VERY nice repaint in the late 90`s. The rear bumper fillers need paint due to cracks, and there is a minor scratch in the drivers door. Also, the A/C needs a charge. The car is a hardtop, that the second owner added a tastefull aftermarket sunroof to. Underside of the car is very nice. I have a replacement power antenea that goes with the car.
The mods are stock unopened motor w/35,xxx miles, PT-61 turbo, CAS V-4 I-C, 65mm t-b and Hemco, 42lb inj, MAF trans + and Extender chip, Alky Control Alky kit, Pat`s 10in converter, fresh trans, added factory posi, ATR single 3in exhaust, and more.
Interior is a 9-9.5 and is super nice. A Scanmaster, boost gauge on the pillar, and oil and water in the console. PW, PL, PS, all the "normal" stuff.
The wheels are G-Body parts powder coated widened rears with M/T dragradials.
NO DISAPPOINTMENTS!
Last October it went 11.77@ 23psi on pump gas.
In the second pic, you can see a pic of the sunroof. It has a mirrored look that goes well with the car. If you like you can have the car with the Torque Thrust wheels instead.
hipsibri@cs.com
Thank you, Brian
NO DISAPPOINTMENTS!
hipsibri@cs.com
Thank you, Brian
