TURBOTIMMER
- Jan 5, 2002
My high mileage driver runs good until it gets up to normal operating temp. Then, it starts to spit, sputter, and finally stall, and leave me stranded
The check engine light never comes on, and the car runs perfect until this happens (with no warning). I've changed the following parts from my GN with no results:
MAF
crank sensor
coil packs
Module
One thing I haven't changed yet is the cam sensor. I recently put a new timing chain and gears in (stock replacement). I noticed that the cam sensor has some shaft wabble, but its the only one I've got. Also, the motor has a slight tick when it warms up which sounds like it could be coming from the cam sensor.
Could the cam sensor wear out that bad and cause a misfire? Also, I can't get the car to act up when its just sitting and idling.
Only when I'm driving it.
Thanks for the help in advance........ Tim
MAF
crank sensor
coil packs
Module
