87 T-Type FS/FT
Seller: Patric
Description: 1987 Buick Regal T
Price: $7500 obo or trade
Details:
I have an 87 Turbo Regal for sale. Im in no hurry to sell the car just have alot of projects going on and trying to thin the heard. The car overall is a very good running, driving and dependable car i drive it everyday and it gets awesome gas mileage. Power windows, power door locks, and remote mirror. Below is a list of the mods and parts on car.
Mods:
-NEW TA49 turbo
-42.5 lb injectors
-Turbo Tweak Chip
-HURST Roll control
-Billet Aluminum Fuel pressure regulator
-Stainless Steel braided line with fuel pressure guage
-Upper plenum spacer
-NEW Turbo inlet bell
-CK Performance Stage 1 transmission with 7000+/- miles
-PATS 3000 stall lockup converter
-GBodyparts Polished Stretch Intercooler
-Terry Houston 3'' Stainless Steel downpipe
-Stainless Steel 3'' Dump Tube
-DMH electric cutout
-2 1/4'' Dual exhaust with Flowmaster mufflers
-Comp Cams valve springs
-Aftermarket Cam (not sure what type or brand)
-Adjustable Wastegate
-NEW Energy Suspension swaybar bushings
-Header flanges cleaned up and drivers header welded
-K&N cone filter
-Engine tie down
-NEW rear brakes and wheel cylinders
-NEW AC Delco R43TS spark plugs
-2 guage pillar pod
-Autometer Sport Comp Silver A/F Ratio guage
-Autometer Sport Comp Silver Boost guage
-Autometer Sport Comp Silver Mini tach w/ pen shiftlight
-Pioneer CD/MP3 player
-Pioneer Speakers in front and rear
The bad:
Car needs some bodywork, bottoms of doors have some rust. The interior is faded and seats are ripped.
Extras:
I have most all gray plastics to go with the car, as well as a gray dash and gray rear seat and console. All parts have been cleaned and are ready to be put in. Also i have upper and lower gray door panels in great shape with concert surround.
Performance:
Car has been a best of 12.4 @ 109mph with a 1.63 60 foot before the transmission and intercooler were installed.​
112,xxx i washed the motor now the car runs for a min and cuts off...thinking i got the wrong thing wet. :frown:
Heres some pics. there a little older. taillights and grill and headlight bezel chrome have been painted black. Car also doesnthave new turbo or intercooler or DP in the pics.
a buddy of mine steam cleand his gn motor a couple years back and it was doing the same thing. he just let it dry out for a couple days and then it started up fine like nothing ever happend
trade ?
1988 notch
MOTOR;less then 1500 miles
dss 331 pro bullet shortblock
prolite pistons
canfield 192s ported.
parker funnel proted intake.
750 double pumper carb.
ford racing valve covers.
edelbrock high volume water pump.
powermaster 140 alternator
new tensioner
smog delete
ac delete
dss oil pan( bung all ready for a blower)
576 lift comp cams cam
10:5:1 compression
griffin 2 row radiator
2 high flow fans
be cool catch can
holley black pump
sumped gas tank
aeromotive fuel filter
-8an braided line
ford racing t-5
king cobra clutch
upr quadrant.
custom aluminum driveshaft
driveshaft safety loop.
subframe connectors
battery box in trunk with shut off switch out the back.
SUSPENSION:
FRONT:
qa1 tubular control arms.
qa1 coilover struts
qa1 caster camber plates
qa1 175lb springs
slotted and cross drilled rotors
new calipers
new hoses
new brake lines
new brakes all the way around
polyurethane rack bushings
REAR:
upr pro series double adjustable uppers
upr adjustable lowers
373 gears
superior 28 spline c clip axles
mac pinion snubber
331 stroker notch- Video
UPDATE!
I can not get the car started after washing the engine. I am lowering the asking price to $7000.​
Check the Coil pack and the wires under it there probly wet just need to dry it out and get new gaskets not a big deal :)
HEY i did the same thing one time dry the the coil pack and control mod.you should be fine
